TwinTurbo.NET: Nissan 300ZX forum - How does the polished VTC shaft look? Any scratches or
jzack
on October 19, 2016 at 9:00 PM
Re: Please read...
posted by slcZ32
on October 19, 2016 at 06:13 PM
abnormal wearing can also cause leaks. The shaft is also part of the sealing mechanism. Post a pix if you aren't sure?
intake cam leak?? pls help
slcZ32
00:16:47 10/19/16
What year is your Z?
-Grimm-
09:44:39 10/19/16
^^^This...more likely just a simple seal leak. Leaks from
jzack
12:57:01 10/19/16
Re: What year is your Z?
slcZ32
18:09:27 10/19/16
Please read...
17:20:53 10/19/16
Re: Please read...
slcZ32
18:13:57 10/19/16
How does the polished VTC shaft look? Any scratches or -
jzack
21:00:24 10/19/16
Re: How does the polished VTC shaft look? Any scratches or
slcZ32
23:36:53 10/19/16
Need to see the VTC gear shaft - that's what mates
jzack
23:51:03 10/19/16
I recently went through this. Thought I had a cam
doug8867
17:57:23 10/20/16
Re: I recently went through this. Thought I had a cam
slcZ32
22:50:34 10/21/16
If it's not the cam gear or the seal..
DAYTONAZ
11:26:23 10/22/16
Re: If it's not the cam gear or the seal..
slcZ32
07:03:55 10/23/16
You just replaced the seals? (n/m)
jzack
12:31:03 10/23/16
Re: You just replaced the seals?
slcZ32
23:43:20 10/23/16
Re: Re: You just replaced the seals?
slcZ32
06:49:19 10/26/16
slcZ32
08:17:09 10/26/16
I may have missed it, where did you get your timing belt kit (n/m)
-Grimm-
09:46:01 10/26/16
